title: "Bounce Rules"
description: "Configure rules to classify bounced emails as soft bounces, hard bounces, or exclude from processing"
url: https://campaigns.kb.mumara.com/en/articles/99-bounce-rules
collection: "Sending Setup"
# Bounce Rules
Bounce rules tell Mumara how to classify each bounced email. You manage them under **Setup → Bounce Rules**. Every bounce is matched against your rules in order from top to bottom — the first matching rule wins — and is classified as one of three types:
-   **Soft bounce** — a temporary failure (mailbox full, server busy, greylisting). The bounce is recorded, but the contact keeps receiving emails since the issue may resolve.
-   **Hard bounce** — a permanent failure (user unknown, invalid address, domain not found). The contact is flagged and will not receive any further emails, protecting your sender reputation.
-   **Exclude from processing** — the bounce is ignored entirely (useful for auto-replies and out-of-office messages).
Each rule has a name, a status toggle, and one or more conditions matched against the **Bounce Code** (e.g. `550`, `5.1.1`), **Bounce Reason**, or **Bounce Description**, using "Is" or "Contains" operators. Multiple conditions are combined with AND logic. Reorder rules by dragging the handle on each row — put specific rules near the top and catch-alls at the bottom. The built-in **Global Rule** stays fixed at the top as the default.
Mumara ships with sensible defaults: **Re-Sync Default Bounce Rules** updates them while keeping your custom rules, while **Reset to Default Bounce Rules** wipes all custom rules and cannot be undone. As a rule of thumb, 4xx codes are temporary (soft) and 5xx codes are permanent (hard).
📖 [**Read the full guide on docs.mumara.com →**](https://docs.mumara.com/campaigns/setup/bounce-rules)
