title: "Branding"
description: "Customize application branding with logos, colors, and custom CSS"
url: https://campaigns.kb.mumara.com/en/articles/91-branding
collection: "Settings & Administration"
# Branding
Branding lets you customize the visual identity of Mumara Campaigns so the platform matches your company's look. You'll find it under **Settings → Branding**, organized into four tabs: **General**, **Images**, **Custom CSS**, and **Head Code**.
On the General tab you set the application title, copyright text shown in the footer, and the login screen's title and slogan, plus a toggle for the contextual help buttons shown in the breadcrumb bar. The Images tab lets you replace the default logos and images: the menu logo (167 x 40 px PNG), login logo (247 x 60 px PNG), favicon (16 x 16 px ICO), preloader image (230 x 230 px JPG), and login banner (1800 x 2000 px PNG). The Custom CSS tab accepts standard CSS that loads after the default styles, so you can override any element — change colors, fonts, or hide elements. The Head Code tab injects custom code into every page's head section, commonly used for external fonts, analytics snippets, or meta tags.
Worth knowing: use the exact image dimensions specified to avoid stretching; each tab has a **Reset** button to restore defaults; CSS changes apply immediately after saving (refresh the page to see them); and if a new logo or style doesn't appear, clearing your browser cache usually fixes it. Only add head code from trusted sources — bad scripts can break pages or compromise security.
📖 [**Read the full guide on docs.mumara.com →**](https://docs.mumara.com/campaigns/settings/branding)
