Branding lets you customize the visual identity of Mumara Campaigns so the platform matches your company's look. You'll find it under Settings → Branding, organized into four tabs: General, Images, Custom CSS, and Head Code.
On the General tab you set the application title, copyright text shown in the footer, and the login screen's title and slogan, plus a toggle for the contextual help buttons shown in the breadcrumb bar. The Images tab lets you replace the default logos and images: the menu logo (167 x 40 px PNG), login logo (247 x 60 px PNG), favicon (16 x 16 px ICO), preloader image (230 x 230 px JPG), and login banner (1800 x 2000 px PNG). The Custom CSS tab accepts standard CSS that loads after the default styles, so you can override any element — change colors, fonts, or hide elements. The Head Code tab injects custom code into every page's head section, commonly used for external fonts, analytics snippets, or meta tags.
Worth knowing: use the exact image dimensions specified to avoid stretching; each tab has a Reset button to restore defaults; CSS changes apply immediately after saving (refresh the page to see them); and if a new logo or style doesn't appear, clearing your browser cache usually fixes it. Only add head code from trusted sources — bad scripts can break pages or compromise security.
