title: "Suppression Lists"
description: "Block email addresses, domains, and IP addresses from receiving emails"
url: https://campaigns.kb.mumara.com/en/articles/86-suppression-lists
collection: "Lists & Contacts"
# Suppression Lists
Suppression lists prevent emails from being sent to specific addresses, helping you honor opt-outs, manage bounces, and protect your sender reputation. There are three types, each under **Lists → Suppression**:
-   **Email Suppression** — block individual addresses. Add them manually, upload a CSV (up to 250MB), or pick a file from the server. Plain-text or MD5-hashed addresses are supported, and a Reference label records why each entry was added.
-   **Domain Suppression** — block every address at a domain (competitors, disposable email providers, high-complaint domains). Enter domains without the @ sign.
-   **IP Suppression** — when a contact opens or clicks, their IP is checked against this list; on a match the contact is suppressed from future sends. Single IPs, ranges, and CIDR notation are supported.
Each suppression can be **Global** (blocks across all lists) or **list-specific**. Contacts are also suppressed automatically by hard bounces and spam complaints, per your bounce rules and feedback loop settings.
Worth knowing: suppression synchronizes every 15 minutes, so new entries may take a sync cycle to fully take effect; IP suppression only applies to contacts who have engaged (opened or clicked); after removing global suppressions, click **Re-Sync Suppression** to update contact statuses; you can bulk-remove entries that share a Reference label; and before un-suppressing anyone, make sure you have permission to email them again.
📖 [**Read the full guide on docs.mumara.com →**](https://docs.mumara.com/campaigns/lists-contacts/suppression)
