title: "Contacts"
description: "Add, import, and manage individual subscribers in your contact lists"
url: https://campaigns.kb.mumara.com/en/articles/82-contacts
collection: "Lists & Contacts"
updated: 2026-11-14
# Contacts
Contacts (subscribers) are the individual email addresses stored in your lists, each with profile data, engagement history, and status flags. Search and view them across all lists under **Contacts → View/Search Contacts**, or click a list's contact count under **Lists → Contact Lists** to see contacts in that list. From a contact's actions menu you can view details, see email history and the event log (deliveries, opens, clicks, bounces), edit, or delete.
You add contacts in two main ways:
-   **Manual entry** via **Contacts → Add a Contact** — choose the list, enter the email, set format, confirmation, status, and fill in custom fields. Each email can exist only once per list.
-   **Import** via **Contacts → Import Contacts** — a 3-step wizard: upload a CSV or TXT file and set options (duplicates: Skip, Update, or Overwrite), map file columns to fields (Email Address is required), then watch real-time progress with counts for imported, duplicate, and invalid rows. The standard import is multi-threaded and runs in the background; you can cancel mid-import.
There's also **Lists → Bulk Update** to apply actions (unsubscribe, delete, change status, etc.) to contacts listed in a file.
Worth knowing: a contact's email address can't be edited — delete and re-add instead; Rocket import is being deprecated in favor of the faster standard import; only Active, non-hard-bounced, subscribed contacts receive emails; and account limits on total contacts can cause imports to fail.
📖 [**Read the full guide on docs.mumara.com →**](https://docs.mumara.com/campaigns/lists-contacts/contacts)
