Contacts
Add, import, and manage individual subscribers in your contact lists
Contacts (subscribers) are the individual email addresses stored in your lists, each with profile data, engagement history, and status flags. Search and view them across all lists under Contacts → View/Search Contacts, or click a list's contact count under Lists → Contact Lists to see contacts in that list. From a contact's actions menu you can view details, see email history and the event log (deliveries, opens, clicks, bounces), edit, or delete.
You add contacts in two main ways:
  • Manual entry via Contacts → Add a Contact — choose the list, enter the email, set format, confirmation, status, and fill in custom fields. Each email can exist only once per list.
  • Import via Contacts → Import Contacts — a 3-step wizard: upload a CSV or TXT file and set options (duplicates: Skip, Update, or Overwrite), map file columns to fields (Email Address is required), then watch real-time progress with counts for imported, duplicate, and invalid rows. The standard import is multi-threaded and runs in the background; you can cancel mid-import.
There's also Lists → Bulk Update to apply actions (unsubscribe, delete, change status, etc.) to contacts listed in a file.
Worth knowing: a contact's email address can't be edited — delete and re-add instead; Rocket import is being deprecated in favor of the faster standard import; only Active, non-hard-bounced, subscribed contacts receive emails; and account limits on total contacts can cause imports to fail.
