title: "Troubleshooting"
description: "Solutions to common installation issues for Mumara Campaigns"
url: https://campaigns.kb.mumara.com/en/articles/77-troubleshooting
collection: "Installation & Updates"
# Troubleshooting
When a Mumara Campaigns installation misbehaves, start with the logs — `storage/logs/laravel.log` for application errors, plus the Apache/Nginx, PHP, MySQL, and Supervisor logs (standard locations for both RHEL-family and Ubuntu/Debian systems are listed in the guide).
The guide covers fixes for the most frequent issues:
-   **Permission errors** — set ownership to the web-server user (`apache` or `www-data`), 755/644 on directories/files, 775 on `storage` and `bootstrap/cache`; on CentOS/RHEL also apply SELinux contexts with `chcon`.
-   **Database errors** — "Connection refused" (check MySQL is running, try `127.0.0.1` instead of `localhost`), "Access denied" (recreate the user with proper grants), and "Unknown database".
-   **500 errors and blank pages** — missing `.env`, missing `APP_KEY` (run `php artisan key:generate`), stale caches, or PHP memory limits; temporarily set `APP_DEBUG=true` to see the real error, then turn it back off.
-   **License validation failures** — the server must reach Mumara's license server over HTTPS; also check for expired keys or domain/IP mismatch in the client area.
-   **Cron and queue problems** — verify the scheduler crontab entry, use full PHP paths, check Supervisor worker status, and restart workers after code changes.
The single most common queue mistake: Supervisor workers are running but the **Queue Driver** in **Settings → Application Settings → General** is still set to Cronjob or Realtime — jobs won't be dispatched to Supervisor until you change it.
📖 [**Read the full guide on docs.mumara.com →**](https://docs.mumara.com/campaigns/installation/troubleshooting)
