title: "Installation Overview"
description: "Choose the right installation method for Mumara Campaigns"
url: https://campaigns.kb.mumara.com/en/articles/74-installation-overview
collection: "Installation & Updates"
updated: 2026-07-22
# Installation Overview
Mumara Campaigns is self-hosted software, and there are three ways to install it depending on your environment and skill level.
-   **Auto-Installer** (~10 min) — a single SSH command that configures everything (web server, PHP, database, cron, queue workers) on a fresh VPS or dedicated server. Choose this if you have root access and want a hands-off setup.
-   **Quick Install** (~15 min) — for shared or managed hosting with cPanel, Plesk, or a pre-configured LAMP/LEMP stack. You upload the files, create a database in phpMyAdmin, and the built-in web installer guides you through configuration.
-   **Custom Install** (~30 min) — a step-by-step manual guide (Apache on AlmaLinux) for system administrators who need full control, run non-standard environments, or deploy in containers.
Whichever method you pick, three prerequisites apply: a valid Mumara Campaigns license key, a domain or subdomain pointing to your server, and a server that meets the system requirements (Linux, PHP 8.4+, MySQL 8.0+ or MariaDB). The simplest decision rule: fresh dedicated server with root access → Auto-Installer; control-panel hosting → Quick Install; everything else, or whenever you want to understand and control each step → Custom Install.
📖 [**Read the full guide on docs.mumara.com →**](https://docs.mumara.com/campaigns/installation/overview)
