title: "Creating Hooks"
description: "Learn how to create and register custom hooks"
url: https://campaigns.kb.mumara.com/en/articles/66-creating-hooks
collection: "Developer Guides"
updated: 2026-07-24
# Creating Hooks
Custom hooks let you run your own PHP code when events happen in Mumara Campaigns. You create a PHP file in the `/includes/hooks/` directory and register callbacks with `add_hook($hook, $priority, $callback)` — files in that directory are loaded automatically, so no other wiring is needed.
Key concepts:
-   **Priority** controls execution order when multiple callbacks share a hook — lower numbers run first (use 1–3 for critical work, 5–10 for standard operations, 10+ for cleanup or logging).
-   Most hooks pass a `$vars` array with event data such as `subscriber_id`, `list_id`, `email`, or `campaign_id`; log `$vars` during development to see exactly what a given hook provides.
-   Fire hooks yourself with `listen_hook()` (synchronous) or `run_hook_in_background()` (queued via Laravel's queue — ideal for notifications, external API syncs, and heavy processing).
-   **Output hooks** like `HeadTop` and `Footer` return HTML strings; retrieve their content with `hook_get_output()`, `hook_get()`, or `hook_get_all()`, and check registration with `hook_exist()`.
Always wrap risky code in try-catch and log instead of re-throwing, so one failing hook doesn't stop the others; enabling hook error logging in Application Settings writes errors to `storage/logs/laravel.log`. Prefer named functions with a unique company prefix for easier debugging, and use `php artisan queue:work --once` to test background hooks.
📖 [**Read the full guide on docs.mumara.com →**](https://docs.mumara.com/campaigns/hooks/creating-hooks)
