title: "Split Tests"
description: "A/B testing to optimize your email campaigns"
url: https://campaigns.kb.mumara.com/en/articles/63-split-tests
collection: "Campaigns & Broadcasts"
updated: 2026-07-24
# Split Tests
Split tests (A/B testing) let you compare two or more broadcast variations to find which one performs best — and optionally send the winner to the rest of your audience automatically. You create test configurations under **Campaigns → Split Tests**, then schedule them under **Actions → Schedule** with Campaign Type set to **Split Test**.
When creating a split test you configure:
-   **Broadcasts to compare** — select two or more; each becomes a variation, sent in equal shares of the test audience.
-   **Winning criteria** — highest open rate or highest unique click-through rate.
-   **Decision percentage** — how much of the audience is used for testing. At 20%, the test goes to 20% and the remaining 80% can receive the winner; at 100%, everyone is split evenly and the winner is only recorded.
-   **Wait duration** — minutes, hours, days, or weeks before the winner is determined.
-   **Action** — just record the results, or send the winning broadcast to the leftover audience.
Worth knowing: test one variable at a time (subject line, CTA, layout) for clear results; allow 4–24 hours for open-rate tests and 24–48 hours for click-rate tests; smaller lists need a larger test percentage (50–100% under 1,000 contacts, down to 5–10% over 100,000); and a split test that is currently running or has already sent can no longer be edited.
📖 [**Read the full guide on docs.mumara.com →**](https://docs.mumara.com/campaigns/campaigns/split-tests)
