title: "Spintax"
description: "Create text variations for personalized email content"
url: https://campaigns.kb.mumara.com/en/articles/62-spintax
collection: "Campaigns & Broadcasts"
updated: 2026-07-24
# Spintax
Spintax lets you rotate words, phrases, or sentences in your emails so each recipient gets a slightly different version. This adds variety, helps you see which phrasing resonates, and improves deliverability by avoiding identical content across a large send. You manage tags under **Campaigns → Spintax**.
To create a tag, click **Add New**, enter a tag name (letters, numbers, underscores, and hyphens only), and list one variation per line — for example a `greeting` tag with Hello, Hi, and Hey. The system randomly picks one value at send time. You then insert the tag anywhere in your content as `{{tag_name}}`, either by typing it or via the **Spintax** dropdown below the editor. Spintax works in the email subject, from name, pre-header, HTML body, and text content of broadcasts and drips, and combines well with recipient fields, e.g. `{{greeting}} %%first_name%%`. A **Pre-Defined Templates** library lets you clone ready-made tags and edit them to match your voice.
Worth knowing: if the same tag appears multiple times in one email, every instance gets the same randomly selected value; tag names can't be renamed after creation (create a new tag instead); deleting a tag that's still used makes `{{tag}}` appear as literal text in emails; and 3–5 consistent variations per tag (similar tone, length, and meaning) is the recommended sweet spot. Content processes in order: dynamic tags, then Spintax, then recipient fields.
📖 [**Read the full guide on docs.mumara.com →**](https://docs.mumara.com/campaigns/campaigns/spintax)
