title: "Routes & Controllers"
description: "Define routes and create controllers for your addon"
url: https://campaigns.kb.mumara.com/en/articles/47-routes-and-controllers
collection: "Developer Guides"
# Routes & Controllers
Routing in an addon works exactly like core Laravel: `Routes/web.php` holds session-based web routes and `Routes/api.php` holds stateless API routes, both loaded by your addon's `RouteServiceProvider` via `module_path()` with the `web` or `api` middleware groups. Group routes under your addon's URL prefix and give every route a namespaced name (e.g. `emailvalidator.rules.show`); resource routes, route parameters, constraints, and API versioning prefixes all work as usual. The provider can even load different route files conditionally by user role (common, admin, client).
Available middleware includes `web`, `auth`, `2fa`, `lang`, and `admin`; apply them on route groups, individual routes, or in a controller constructor. You can also write addon-specific middleware in `Http/Middleware/` (e.g. a quota check) and register it with `aliasMiddleware()` in your service provider before using the alias in routes.
Controllers live in `Http/Controllers/` under your addon namespace and extend the core `App\Http\Controllers\Controller`. Keep them thin: validate with form request classes in `Http/Requests/` (rules, authorize, custom messages), authorize with policies via `$this->authorize()`, and move business logic into services. Web actions return addon views with the `youralias::view` syntax; API controllers should return a consistent JSON shape — `success`, `data`, and pagination `meta` on success, `success: false` with errors and a proper status code on failure. Webhook endpoints can drop auth with `withoutMiddleware()`.
📖 [**Read the full guide on docs.mumara.com →**](https://docs.mumara.com/campaigns/addons/routes-controllers)
