title: "Addon Lifecycle"
description: "Installation, updates, and uninstallation of addons"
url: https://campaigns.kb.mumara.com/en/articles/44-addon-lifecycle
collection: "Developer Guides"
# Addon Lifecycle
Addons move through a defined lifecycle: Available → Installing → Active, with paths through Updating, Inactive, Uninstalling, and Removed. State is tracked in two places — the `addons` database table (metadata, versions, status) and `storage/addons_statuses.json` (enabled/disabled flags for laravel-modules).
During installation the system runs pre-install checks (dependencies, license), then your `install_addon()` lifecycle function from the addon's root `functions.php`. It takes no parameters and must return an array with a `success` key — return false with a message to abort. After success the system automatically creates the `addons` record, enables the module, runs migrations, executes versioned SQL files from `Settings/install/`, publishes config and translations, creates the public asset symlink (`public/Addons/{Name}` → addon `public/`), and clears caches. Updates call your `update_addon()` function, which must return `success` plus an `update_url`; the system downloads and extracts the ZIP, runs new migrations, applies install SQL files newer than the current version, and updates the version record. Activation/deactivation only toggles the module's enabled state — the symlink is created at install time, not activation.
There is no `uninstall_addon()` function to implement: on uninstall the system rolls back migrations, removes the symlink, and disables the module automatically; put extra database cleanup in `Settings/uninstall/uninstall.sql`. Version your install SQL files (v1.0.sql, v1.1.sql), test migration rollbacks, and make sure uninstall removes everything your addon created.
📖 [**Read the full guide on docs.mumara.com →**](https://docs.mumara.com/campaigns/addons/lifecycle)
