title: "Configuration"
description: "Configure addon metadata, settings, and navigation menus"
url: https://campaigns.kb.mumara.com/en/articles/38-configuration
collection: "Developer Guides"
# Configuration
An addon's configuration is split across several files, each with a distinct job. `Settings/config.php` holds the metadata shown in the addon manager — display name, vendor, type, logo, slider images, version, base `route` prefix, and licensing (`license_type` of `native`, `marketplace`, `remote`, or `free`, plus `native_addon_name` when native). A `new_version_url` returning JSON with version, changelog, and release date enables automatic update checks. `module.json` is the manifest: name (must match the directory), lowercase alias, load `priority`, the service providers to register, PHP `files` to autoload, and `requires` for dependencies on other addons (dependencies load first).
Runtime settings live in `Config/config.php`, accessed via `config('youralias.key')` and overridable through `php artisan vendor:publish --tag=youralias-config`; use `env()` for API keys and other secrets. `menu.json` defines sidebar navigation — each entry has a title, HTML icon, relative URL (or `#` for parents), `hidden`, `hasChild`, and a `childrens` array for submenus. `composer.json` declares PHP dependencies, merged into the main app by composer-merge-plugin (run `composer update` from the project root). `webpack.mix.js` compiles `Resources/assets/` sources into the addon's own `public/` directory.
For user-configurable settings, store values in a dedicated database table with a small settings model exposing static `get`/`set` helpers, optionally keyed per user — don't write user settings into config files.
📖 [**Read the full guide on docs.mumara.com →**](https://docs.mumara.com/campaigns/addons/configuration)
