title: "Best Practices"
description: "Guidelines and patterns for building quality addons"
url: https://campaigns.kb.mumara.com/en/articles/37-best-practices
collection: "Developer Guides"
# Best Practices
These are the recommended patterns for building maintainable, performant, and secure Mumara Campaigns addons — worth reviewing before you release anything. The core principle is to follow Laravel conventions: keep controllers thin, push business logic into service or action classes, use jobs for async work, and events/listeners for decoupled communication.
The key areas covered:
-   **Database**: guard migrations with `Schema::hasTable()`/`hasColumn()` checks, index frequently queried columns (including composite indexes), and wrap multi-step writes in `DB::transaction()`.
-   **Performance**: eager-load relations to avoid N+1 queries, process large datasets with `chunk()` or `lazy()`, cache expensive lookups with `Cache::remember()`, and dispatch heavy work to queue jobs instead of blocking requests.
-   **Security**: validate all input with form requests, use policies and `authorize()` for access control, never expose API keys in responses, and `encrypt()` sensitive stored settings.
-   **Hooks**: keep hook callbacks lightweight (queue heavy work), pick sensible priorities (low numbers run first, 50+ for logging), and always return a string — empty when there's nothing to output — from output hooks.
Also: degrade gracefully when external APIs fail, throw specific exceptions with meaningful messages, log with appropriate levels and context, give users flash messages and progress feedback, write feature tests, and include a README. The doc ends with a pre-release checklist covering all of these.
📖 [**Read the full guide on docs.mumara.com →**](https://docs.mumara.com/campaigns/addons/best-practices)
