title: "DB Check"
description: "Database diagnostics and health check"
url: https://campaigns.kb.mumara.com/en/articles/116-db-check
collection: "Settings & Administration"
# DB Check
The Database Toolkit, under **Tools → DB Check**, identifies database-related issues and fixes them automatically. It has two functions: running migrations to sync your database schema with the current Mumara version, and checking that all tables have the required indexes for fast queries.
Clicking **Run Migrations** clears the migration tracking history and re-runs all migration files from the beginning, applying any missing tables, columns, or constraints. Use it after updating Mumara, after restoring from a backup, when you hit "table not found" or "column not found" errors, or when support recommends it. The operation is designed to be safe — it adds missing elements without destroying existing data — but always keep a current backup before running it in production.
The collapsible **Database Indexes** section checks every table in realtime against your actual database structure. Tables with all required indexes show a green "INDEXED" badge; tables with missing indexes can be fixed individually with the apply button next to each one, or all at once via **Apply All**. Missing indexes are a common cause of slow page loads, timeouts on large lists, and high database CPU usage, so this is worth checking whenever performance degrades.
Worth knowing: applying indexes requires the database user to have CREATE INDEX privilege and enough disk space; if migrations or indexes fail, check Debug Logs for the specific error and retry during a low-traffic period.
📖 [**Read the full guide on docs.mumara.com →**](https://docs.mumara.com/campaigns/tools/db-check)
