Evergreen Stats, under Statistics → Evergreen Stats, tracks the ongoing performance of your evergreen (recurring) campaigns. Because evergreens execute automatically on a schedule, each execution is recorded as a separate run, and this page lets you review every run individually and spot trends across them.
The main list shows each evergreen campaign with its total number of runs, the date of the previous run, and the scheduled next run — a quick way to confirm a campaign is executing on schedule. Click the Runs count or the Details icon to open the runs list, where each row is one execution showing its own contacts, sent, skipped, opens and clicks (Unique/Total), and unsubscribes. A dropdown lets you switch between evergreen campaigns without going back, and you can filter by admin or search by name. Opening any run's Details gives you the complete statistics interface used for broadcasts — Summary, Opened, Clicked, Unsubscribed, Bounced, Complaints, Logs, and A/B tabs — plus per-run export.
Worth knowing: each run technically gets its own campaign ID, and the Contacts count naturally varies between runs because evergreens send to whoever matches your criteria at run time — new list members get the next run, while contacts who already received the evergreen may be excluded depending on your settings. Compare open rates across runs to detect audience fatigue, and watch the Skipped count: if it keeps growing, you may be re-targeting contacts who already received the campaign.
